Prop Recommendations 29' Profile Twins with Notched Transom >
Old 01-16-2020 | 08:31 PM
Default Prop Recommendations 29' Profile Twins with Notched Transom
29' Profile running Bravo one drive 1:50 gears looking for prop recommendations It has twin 7.4L L29 mpi motors, notched transom I'd like good out of the hole and decent 60'sh top end Thinking Bravo one 22p four blades???
MooresWarlock is offline
Old 01-17-2020 | 01:04 AM
I would think it will run upper 60's easily. I would start with 24" Bravo 1 props or maybe even 26's depending on what rpm you want to spin the engines.
Griff is offline
Old 01-17-2020 | 11:14 AM
Default Thanks
Thanks for the info Griff - it's a pretty heavy boat and the motors are only 310hp so not sure I can spin the 26's. Next question - setting up the drive rotations - Rotating Outward or Inward?
Old 01-17-2020 | 01:12 PM
Spin them out
Being 310hp, you are only going to spin them up to about 4600 rpms so 26's may work fine.
Griff is offline
Old 01-17-2020 | 06:15 PM
Originally Posted by Griff
Spin them out
Why out?
hogie roll is offline
Old 01-18-2020 | 09:52 AM
Copy that Thx for the update Griff👍🇱🇷
Old 01-18-2020 | 12:38 PM
Originally Posted by hogie roll
Why out?
Because a 29' V bottom with twin BBC's wont need the added bow lift that spinning inward would create.
Griff is offline
Old 01-29-2020 | 10:21 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Why out?
Once you are ready to test, we can help you with test propellers. We have some BBLADES branded props we can supply you to test as well.
You can easily test inward and outward rotations.
Brett
[email protected]
bbladesprops is offline
Old 01-29-2020 | 02:54 PM
Default Thanks!
Thanks for the update Brett! I'll definitely keep you posted! Quick question - on the Bravo One 4-blade props - I see some with ventilation holes (approx 3/4" - 1" diameter) on the diffuser - better 'out-of-the-hole' performance??
Old 01-30-2020 | 01:42 AM
I highly doubt you would need or even see any benefit from props with ventilation holes.
Griff is offline
