Go Back  Offshoreonly.com > Technical > Electronics
Mobile vessel view >
Mobile vessel view
Mobile vessel view
Old 01-20-2020 | 06:13 PM
Default Mobile vessel view
Does anyone use this? How do you like it? Eventually I want to put a MFD in but till then I am thinking about a panel mounted iPad and the vessel view. To my understanding it will give me all the engine instruments, some how fuel quantity, speed, etc. is this what I’m thinking it is or am I off?
thanks y’all
Iflylow57 is offline
Old 01-21-2020 | 06:41 AM
thanks y’all
I have build a panel with IPad mini on it to use the Mercury VesselView.
Have not tested it with the engine running yet but I think it will be perfect. I can get all the fault codes in the VesselView application and much more data like the engine instruments, fuel, speed, rpm etc.
Here is a picture of my panel on my Chris Craft 260 Stinger I finished last week.
JohanSweden is offline
Old 01-21-2020 | 07:20 AM
Awesome let me know what you think after you fire it up!
Old 01-24-2020 | 10:15 AM
This is all you need. And an I Pad
Amazon Amazon
Blueabyss is offline
Old 01-24-2020 | 10:54 AM
Originally Posted by Blueabyss
I have 2 NEW listed forsale $150 each to your door!
NEW Mobil vessel view
PA.WOODCHUCK is offline
Old 02-24-2020 | 12:25 PM
I have it and it works great. The fuel quantity from the way I understand it so far is a calculation. If you put 10 gallons in then you tell vessel view you put 10 gallons in and it will calculate what you have left by the fuel flow. Seems to be working so far. Thinking I need the gateway to my simrad to make the fuel quantity work. The panel is crazy simple now. I had gauges all over the place before.
Gunradd is offline
Old 02-24-2020 | 12:59 PM
I would go with the vessel view link vs. the gateway, then you will get the vessel view interface on the simrad vs. the simrad generic gauges...
30outlaw is offline
Old 02-24-2020 | 01:17 PM
I would much rather have the vessel view link but from what I'm told it wont work with my simrad NSE 12 I guess its to old. So I got the vessel view mobile to get the detailed info from the motors. I will probably get it in the future though when I upgrade simrads. Thanks though for the info.
Gunradd is offline
Old 08-03-2020 | 01:21 AM
im in the process of going digital on my gauges .I have a 34 Fountain with triple 300xs at the moment on simrads. I purchased the gateway ( not knowing any better) but have read that the vessel view link is way better The gateway seems very generic and plain.. any advice is appreciated.. also where is the best place to purchase the vessel view link multi engine from?? thanks
speeder4life is offline
Old 08-03-2020 | 07:45 AM
simrad, I would get the link, then you will have the OEM vessel view interface biggest factor here is the warnings, not just a generic "fault", but you will get an "injector fault" . i would suggest find your local mercury dealer and start a relation with them... I get a very generous discount from my dealer cause i said i will sped x amount with you on a yearly basis can you help me out, still can find it cheaper online but because of the business/relationship i can call and ask any questions i'v borrowed shop manuals from them etc. that is worth a little more.... otherwise the part numbers are in the pdf below and befriend your self with google....
https://embed.widencdn.net/pdf/plus/...b.pdf?u=orhjei
30outlaw is offline
