Trailer for twin stepped Fountain ? >
Old 02-01-2020 | 03:22 PM
Default Trailer for twin stepped Fountain ?
My question is a very basic one. Currently I have no trailer just a pier lift with bunks set to accommodate the stepped hull. If I look at purchasing a trailer online it's easy to find the proper length but how about the depth and location of the steps. Are the trailers adjustable or do I need a custom made trailer to support the boat properly? Does it
matter? Thanks!
Pat Ousborne is offline
Old 02-01-2020 | 03:41 PM
F-2 Speedy's Avatar
For sure it matters, you dont want a stepped hull sitting on a flat bottom trailer for any length of time, what some do is add height to the bunks in the step area to support the boat properly, but I think most are custom built to to the boat or at least mine is,
F-2 Speedy is offline
Old 02-10-2020 | 09:19 AM
Call Myco and have them build you a custom trailer. It will fit the hull perfectly.
PremierPOWER is offline
Old 02-10-2020 | 11:40 AM
It really depends on the trailer. Some are adjustable to a certain extent and you can use thicker bunks or build up the bunks as needed for the steps.
Griff is offline
Old 02-16-2020 | 10:42 AM
I sell venture trailers, not to far from you, our trailers are adjustable, and can have them set close or spot on. What size Formula ? feel free to contact me @ 540-786-8111 to answer any questions
ezstriper is offline
