2008 38ZSF Seat Removal
Anybody able to offer tips on removing the seat back on the transom cockpit seat? Looking to reupholster and the bottom came off readily - just as soon not break anything getting off the seat back.
Thanks in advance
Thanks in advance
Removed mine last year. Run your fingers along the bottom of the seat back and feel for holes in the vinyl. Use a long phillips head screwdriver through the vinyl access hole and you'll find the screw heads in there.
Next, lift up access panel to go under floor where the generator and batteries are. There are 5 or 6 more screws all the way back past the live wells that you'll have to take out that attaches the upper portion of the back of the seat.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
