Looking for replacement 32 89730 >
Old 03-30-2020 | 07:04 PM
Default Looking for replacement 32 89730
I blew a cooling hose (starboard thermostat to manifold) on one of my big blocks. I have attached a picture with the # 32 89730. The internet tells me this has been updated to 89731 BUT when I look at the picture, the hose seems to be significantly longer and has too many bends.
Can anyone direct me to a direct replacement hose?
Thank you,
Tom
F14A water jet is offline
Old 03-30-2020 | 09:14 PM
try 897301
compedgemarine is offline
Old 03-30-2020 | 09:50 PM
I have 2, $20 ea plus shipping
Unlimited jd is offline
Old 03-31-2020 | 07:11 AM
Mbam's Avatar
Offshoreonly Advertiser
Thank you,
Tom
Hmmm looks like the straight end might have been cut. Can you post another photo or 2 with a tape measure in the picture and maybe with the straight end in front. I can pull a 897301 off the shelf and compare.
https://www.mercruiserparts.com/897301-hose-molded
Mbam is offline
Old 03-31-2020 | 06:26 PM
See below...THANKS!
Old 03-31-2020 | 06:28 PM
One issue seems to be that the manifold pipe where the hose attaches does not have a "ridge" to help hold the hose in place...I'm gonna double hose clamp.
Old 04-06-2020 | 08:41 AM
Thank you for your help...and discoveries?
Old 04-06-2020 | 09:00 AM
Mbam's Avatar
Wow the new 897301 looks completely different!
Can you tell if your hose has been cut? Post a close up photo of the end. Also a photo of the engine showing where it attaches at both ends.
Mbam is offline
Old 04-06-2020 | 09:15 AM
It looks like the hose has been cut down to mate up with the GIL exhaust manifolds. It also looks like the T going into the manifold has a "smooth" contour (does not have a ridge/lip for the hose to grab). See attached (not mine but very close). I am sure the boat has been run like this for a number of years (200+ hours) so I think it just vibrated loose and I will double the hose clamps for safety.
Thanks again,
Tom
Old 04-06-2020 | 09:18 AM
Mbam's Avatar
O - now I see. It wouldn't hurt to pull the fitting and have someone machine a section to give you a lip. We do that all the time when we make fittings.
Mbam is offline
