502mag EFI distributor problem >
Old 04-02-2020 | 09:23 AM
Default 502mag EFI distributor problem
I'm building gen V 502mag EFI for more power and change mefi to holley terminator X. Also change distributor to Holley dual sync so I can make sequential injection mode. Hope that help idle quality with bigger roller cam.
Problem is that HEI style cap is so high that it will not fit under upper intake. Does any manufacturer make lower profile cap where spark wire connectors are pointed sideways?
Another option is machine spacer plates below upper intake, but it's not good choice because I already modify lower intake ports.
Lowering the distributor is quite complicated.
ksalmine is offline
Old 04-02-2020 | 10:13 AM
personally,I'd cut the upper manifold so the distr. cap fits and then weld up the hole.thats if you can't find a lower cap for that distr.
sutphen 30 is offline
Old 04-02-2020 | 10:33 AM
Change back to Delco EST
AllDodge is offline
Old 04-02-2020 | 12:09 PM
F-2 Speedy's Avatar
can you run the crab style cap with this distributor ??
F-2 Speedy is offline
Old 04-02-2020 | 12:18 PM
GPM
I don't know if this would work for you, https://www.jegs.com/i/MSD/121/8541/...All%20Products
GPM is offline
Old 04-02-2020 | 01:54 PM
I just paint parts, welding is not first choice. And upper intake may twist from welding.
I found crab cab also in internet, but it looks so low that it won't fit to hei distributor. Does anybody know the truth? I have one MSD billet hei distributor cap and it fit well to Holley distributor. Soif crab cap fit MSD HEI, it should solve problem
ksalmine is offline
Old 04-02-2020 | 02:01 PM
F-2 Speedy's Avatar
Id call Holley Tech and tell them your issue and see if they have an answer....... I think there is a low profile HEI cap out there but dont have a part #
Old 04-02-2020 | 02:05 PM
My worse english doesn't allow that but maybe I will mail them. Tried first here because somebody else may have had same problem before.
ksalmine is offline
Old 04-02-2020 | 02:06 PM
F-2 Speedy's Avatar
that looks to be a good 3/8's of an inch from clearing
Old 04-02-2020 | 02:11 PM
1/2" at minium so wires can pull off without remove plenum. water cut spacer flanges do the job but crab cap is most simple way if it fit
ksalmine is offline
