Electric Fuel Pump to replace mechanical pump on 500 EFI >
Old 04-03-2020 | 09:04 AM
Default Electric Fuel Pump to replace mechanical pump on 500 EFI
Anyone have any history with going from the mechanical fuel pump to electrics on 500 EFI's , or any Merc Racing EFI's?
Was looking at the Holley Red Pumps that are set at 7PSI to feed the stock electric pumps. Not sure if 7 PSI is enough (though flow should be there) or the best way/location to mount the pump.
I know electric to replace mechanical may have drawbacks. But water pump failures due are more common due to the lube problems in those applications.
snowrunner is offline
Old 04-03-2020 | 06:24 PM
Weldon 1100A pump will do you. Plus its the only pump that is designed to draw fuel and not gravity fed. I have them on 3 boats and super quiet. You could use this as a stand alone pump with regulator. I'd run an Aeromotive regulator.
larose481 is offline
Old 04-03-2020 | 06:32 PM
Alot comes with switching up fuel pumps. I used a weldon but had to install a new switch that can accommodate return style system, along with a regulator and return lines to both tanks
Not really a drop in solution
Hdgasser is offline
Old 04-03-2020 | 06:57 PM
Isn’t the 1100A an Aeromotive? I looked at that as well, its the setup recommended by Whipple.
The Holley setup seems simpler as it still uses the cool fuel. The Aeromotive needed a small cooler /rrturn which I don’t understand how to setup.
Old 04-03-2020 | 10:17 PM
Hdgasser is offline
Old 04-04-2020 | 07:05 AM
Thanks for clarifying, confused with the A1000 Aeromotive
Old 04-05-2020 | 10:05 PM
Thats the one.
Old 04-07-2020 | 09:35 AM
Didn't realize Merc had a 'fix' for the vapor lock situation( Kit 862264A2 ) any one have luck with that? Nice simple package from what I can see (all the viring and plumbing is included - with instructions for people like me with little real understing of the fueling side), curious if it works well for stock Mec applications?
Old 04-09-2020 | 10:21 AM
I installed it on an old 27 Fountain I had with 502. That thing wouldn't start for $hit after being rafted up for a while, was towed in so many times - wife was always scared to shut off the boat. I tried everything until I discovered that pump kit that Mercury has. It ABSOLUTELY cured the issue on that boat. Very easy and quick to install. I did not install the backflow valve that they also prescribe may fix the problem. There is a service bulletin that shows the pump kit.
Terry
ALL_IN! is offline
Old 07-03-2020 | 08:44 AM
Terry
I'm ready to jump on that kit now, still no regrets of buying it ?
oldscoolscarab is offline
