Gear oil OEM vs non OEM
Old 04-13-2020 | 05:19 PM
Default Gear oil OEM vs non OEM
First of all... I have always used Merc OEM gear oil and will continue to. Is there really any difference between them? Merc has the SAE-90 spec and others usually are 80-90 or 85-90 and state for marine use. Does Merc have some "magic" additive that the others don't
thanks
PA.WOODCHUCK is offline
Old 04-13-2020 | 05:22 PM
been using 75-90 automotive synthetic GL5 gear lube for years and had no issues,
boatnt is offline
Old 04-13-2020 | 05:38 PM
[QUOTE=PA.WOODCHUCK;4733613]First of all... I have always used Merc OEM gear oil and will continue to. Is there really any difference between them? Merc has the SAE-90 spec and others usually are 80-90 or 85-90 and state for marine use. Does Merc have some "magic" additive that the others don't
thanks[/QUOTE
Magic additive is "green sludge & $$$$$".
GETTINBYE is offline
Old 04-13-2020 | 05:47 PM
What drive are you putting it in? In one boat I put a high end gear oil in started having cone clutch slipping issues, that went away when I put merc oil back in. I believe the merc oil has a friction modifier in it. Also I believe there is no difference between the Sierra brand gear oil and the mercury.
Unlimited jd is offline
Old 04-13-2020 | 06:43 PM
Bravo 1 X in current boat
Old 04-13-2020 | 06:48 PM
Walmart usually has it for 9 bucks a quart or so....
phragle is offline
Old 04-13-2020 | 07:05 PM
BUP
Its mineral base the Merc High performance gear oil and is a GL 4 spec. All the 75 w - 90 syns are GL 5 spec.
You can not use Merc HP gear oil in Volvo SX / DP and current drives with Nedox cone clutch. Some added info for the Volvo owners.
BUP is offline
Old 04-13-2020 | 08:47 PM
thanks
You can also use the "Quicksilver High Performance gear Lube". It’s the same blue/green stinky stuff as the "Mercury High Performance Gear Lube Plus", just a different bottle.
Bare Bones is offline
Old 04-14-2020 | 01:27 AM
Sierra and Merc are not the same.
Quicksilver products are the exact same product as Merc with a different label and QS can be sold at non Merc dealer retail places.
Griff is offline
Old 04-14-2020 | 06:54 AM
Active Streak: 30 Days
Also available at Menards, if you have one by you. My local Walmart had 2 bottles last time, Menards had 20.
Helmwurst is offline
