Anyone got a pair of blower water relocators?
Weiand 177s - pair - thought I had room for thermostat housings but don't (the snouts are in the way) so looking for a pair of relocators or ideas if there is a better way.
I plan to run closed cooling without thermostat (not crossovers).
Thanks as always
Swamp
Thanks as always
Swamp
You will still want to run some type of restrictor plate in lieu of T stat. I would probably just run a 120* T stat.
They do make offsets for SC's
https://www.summitracing.com/search?...ostat%20offset
I am pretty sure I have a bunch of new ones up in our "attic" I'll try and remember to take a look later.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Thanks Griff - saw these but trying to cheap out if used ones are around.
To your comment above - this is a closed cooling setup so antifreeze running through block and manifolds - why do I need "restrictor"? Edumakate me Bro
I took a look, don't have those. I have 5 of these. I knew it was something thermostat related. Sorry
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
Let's make a deal
Let's make a deal
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
The coolant can flow too fast and can leave hot spots/steam pockets toward the back of the engines.
