Any good threads/videos on Bravo rebuilds??
I think I'm loosing the cone clutch as my drive bangs into gear every once and a while... I figure a rebuild can't be that difficult... I've set up differentials rebuilt manual and auto transmissions and countless motors. Anyone know where I may be able to find a good how to?
Did some searching but couldn't find what I was looking for with all the related questions.
Thanks in advance.
Travis
Thanks in advance.
Travis
You might be able to find a service manual that has all the pictures and spec's ?? I have an old Service Manual #11 , it show pretty good detail on disassembly and rebuild. I rebuild my pivot pins, bellows, seal etc last year using it.. Pretty easy to follow. Depending what vintage drive you have there should be a manual available. There is a company called Precision Services, AKA, MerCruiser Tools and Supplies for the do-it-yourselfer, they sell a lot of tools, parts and items neede for drive repair.
Your drive would use manual 11 to start with. I say to start because there are some updates which I found could be used when rebuilding my old one. I used some info from manual 28 and compared
With your drive not shifting properly the most likely problem is the clutch shaft/gears needs to be deglazed or replaced. There are many tools which will be needed, so unless your going to continue to use them from time to time, or like me, was unable to find someone local with the expertise, I would have it done.
I spent more then $700 in tools just to rebuild my lower B3
Also note when repairing the different case numbers and gears. There are some Bulletins which cover updates and repairs. All depends on what you have and will need
https://forums.iboats.com/forum/engi...utdrive-repair
