Adding  a 525sc blower to a slightly built 454?? >
Old 05-11-2020 | 09:25 PM
Default Adding a 525sc blower to a slightly built 454??
So looking for a little input. I have a 454 that was bored .60 over. 9.0 compression. forged crank, forged pistons, 088 rectangle port heads, micro power flow exhaust, and what is basically a 500hp cam(custom ground but basically the same with slightly more overlap but not enough to have reversion issues. I have never dynoed the motor but based on builder estimates and performance motor is making around 425-450 hp. I have the opportunity to buy a recently rebuilt factory 525 weiand 177 blower complete with new belt, 2 pulleys 4and 5lb 1050 dominator carb and all needed parts for install. Anyone have any input on if this is a feasible match or would I just be making a time bomb? I'm nor looking for crazy hp. would like to be in the 550-600 range and still be able to run pump gas.
Jbsk731 is offline
Old 05-11-2020 | 09:35 PM
There is no way to be able to say its a 4# pulley and 5# pulley as boost pressures will vary some based on each engine.
The stock OEM 525SC top pulley which was 3.5" made 5.5# of boost on the 525SC using the stock 7" lower pulley.
You should be able to safely run 4 lbs of boost with 9.0:1 on 93 octane fuel.
Griff is offline
Old 05-11-2020 | 09:42 PM
Griff, I was reading through the other thread that was very similar however I saw his questions were based on base 454 mag vs mine which has been mildly built. would the 500hp cam work well with this blower? I also saw you talking about ignition. My boat originally came with the 454 "powertuned" 300hp 454 with a bravo 3. I am still using the stock ignition and am not sure what it has for timing. I am very interested in making this happen but dont want to turn a perfect running motor into and anchor. I really appreciate your time and knowledge on this matter.
Jbsk731 is offline
Old 05-12-2020 | 01:23 PM
The cam will work fine. I'm not familiar with the type of ignition you have. Bottom line is you will want about 32* of total advance at WOT.
Griff is offline
Old 05-12-2020 | 04:51 PM
I installed a 177 supercharger on a bone stock 330 horse non Mag 454. Set the total advance to 28 degrees ran 4.5-5 lbs of boost for 13 years in my 251 Convincor. The boat would run 70-71 mph @4700 rpm. After a few years I installed CMI headers, gained maybe .5-1 mph... Then I installed the Merc 420 cam made by Crane, I maybe gained another .5-1 mph. I ran that boat hard for 13 years and it never gave any issues. Finally I switched to a 24 pitch prop and spun it to 5400 rpm and it lost oil pressure and spun a main bearing. I built a new 454 with forged pistons and full roller cam Cast Iron Merlin heads and out the 177 on it. I thought I was going to have an 80+ mph boat. It only went 75. All that being said, I think that little supercharger is great for stock engines as mine was originally but they don’t perform any better to built engines. Just my experience.
Bigsbetter is offline
Old 05-12-2020 | 10:21 PM
your engine is perfect for the upgrade in question,550 hp can happen with the correct tuneup.
mike tkach is offline
