Cabin and side of hull carpet
Need to know where to get the glue on carpet that is glued to cabin walls and inner sides of hull and rear seat. I replaced the fuel tank and pulled the rear seat apart while doing so and would like to replace the carpet. the old seat had holes for speakers and I don't want them on the seat any more. Also would like to recover cabin floor and bunks. I don't even know the name of this carpet. Its nice cause it doesn't hold water. Any info would be appreciated.
I posted this back in 21 I ended up regluing the original stuff back. Last week I decided to sand down the rolled on Gel coat I put on the floor and spray on gelcoat. I also came up the side sin the cockpit about 4''so I pulled the black spray glued carpet off again. Though the sprayed on gelcoat came out pretty nice it was not an easy job. My problem is I still can't find the name of this carpet so I can replace it. It has no backing on it and want to replace it. E bay has some carpet but they say its 1/8 of in inch. The original is thicker than that. Any help with the make and name of this stuff would be appreciated. I wanna get it finished and go boating.
