177 snout pulley - trick to pull it? >
Old 05-13-2020 | 10:46 PM
Default 177 snout pulley - trick to pull it?
Merc 525SC blower - I need to pull the snout upper pulley and dot want to break anything by forcing things. Can't seem to find info anywhere on-line.
Is the center bolt a "left loosey"?
I assume it has locktite on it ... but didnt try too hard until I asked you guys.
I have a good puller - will I need it?
Thanks!
Swamp
Swamplizard is offline
Old 05-14-2020 | 06:35 AM
resurrected's Avatar
When I pulled mine, it slid off pretty easy. The bolt was standard thread with locktite, strap grip to hold the pulley and small impact gun is what I used.
Mine are the 177's
A little locktite and torque to 30ftlbs for re-assembly
resurrected is offline
Old 05-14-2020 | 07:57 AM
Thanks Bro - exactly what I needed. I tend to force sh!t and break it.
