468 build
Old 05-19-2020 | 07:54 PM
Default 468 build
Hey guys building up a 468 and wanted to know if anybody has used this cam...https://www.cpperformance.com/p-1162...ifter-kit.aspx. And if used how do you like it? Pros and cons...
Also I can’t find a recommended compression ratio for this set either.. I’ll probably be around 9.5-1... 6k rpm max, very light boat, cmi headers with threw transom tips... any recommendations
picca00 is offline
Old 05-19-2020 | 09:56 PM
Rookie's Avatar
I think it would be a nice mild build. I used to run 9.7:1 for years and I believe that cam will run out of power well before 6000 RPM.
I just built 2 Merc 420's (454's) with upgraded 500 EFI cams 230/236, 0.598"/0.610"
Rookie is offline
Old 05-19-2020 | 10:16 PM
Rookie are you running dry exhaust? What’s that max lift you can get away with staying with reasonable compression?
picca00 is offline
Old 05-20-2020 | 07:37 AM
Lift doesn’t have a relationship to compression. Duration does. In general, for a given fuel octane, more duration will allow more compression.
hogie roll is offline
Old 05-20-2020 | 10:35 AM
I used the 500efi cam in my 420's and they work great.
TylerBurich is offline
Old 05-20-2020 | 11:04 AM
X'2 Agreed, I just did the same with a 454 Mag. Same Crane 168731 112* with 9.5:1.
KRAUSMOTORSPORTS is offline
Old 05-20-2020 | 11:10 AM
what heads did you use and what’s the approx hp?
picca00 is offline
Red Zone? Maximum Endurance Roller Lifter [3372RH] - $1,065.00 : ISKY Racing Cams, Do It Right
no needle bearings!!!!
flashgordon is offline
Old 05-20-2020 | 11:11 AM
SB
The 731 is a tad smaller than the 500EFI cam. (226 vs 230 int duration at .050”)
Still a good choice for many 454/502 builds.
SB is offline
Old 05-20-2020 | 01:16 PM
hows the 525efi cam with a carb?
picca00 is offline
