How to setting timing on a 1994 454 mag with thunderbolt V ignition >
Old 05-20-2020 | 03:56 PM
phughes69's Avatar
Default How to setting timing on a 1994 454 mag with thunderbolt V ignition
Who knows how to set timing on a 1994 Gen V 454 with a thunderbolt V distributor. It doesnt have a knock sensor and no purple/white wire to put it into base mode. only 4 wire coming out of the advance module. A purple wire to the + coil. A grey wire to the - coil A white/green and a white/red wire going to the the inductive pickup in the distributor.
phughes69 is offline
Old 05-20-2020 | 04:15 PM
Originally Posted by phughes69
Who knows how to set timing on a 1995 Gen V 454 with a thunderbolt V distributor. It doesnt have a knock sensor and no purple/white wire to put it into base mode. only 4 wire coming out of the advance module. A purple wire to the + coil. A grey wire to the - coil A white/green and a white/red wire going to the the inductive pickup in the distributor.
Its not a TBV its a TB4, just point and shoot
AllDodge is offline
