Why do my Oil Filters get so Tight
I only put my oil filters hand tight, but every time I change my oil the filters it feels like Bigfoot put on the filters why is that? Filters are Wix gold 1060.
how tight is hand tight??? ....you only need to go 1/4 to 1 full turn after the filter makes contact with the housing/ block depending on filter mfg reccomendations
It would be interesting to see if it is simply the heat-soak from being in a closed engine compartment x "X" hours between changes is the actual culprit in terms of actually effecting the thin barrier film of oil or the sealing ring
