Chris Craft Stinger 222
Hey guys, it's time again. Last time I posted I was asking about a '86 Chris Craft Stinger 26 footer w/twin 350's, the feedback was greatly appreciated, and I used your advice to hold off on the purchase of that one. Now you may think I'm a glutton for punishment but, here it is. I am looking at the purchase of a '86 Chris Craft Stinger 222 w/single 454, Alpha-one (with heavy duty gears?), and thru-hull exhaust. She has a center helm, with three seats across (with fold-up bolsters), forward and down on the port side, a cuddy with v-berth and two facing seats. Aft and over the back of the gunell to gunell three seats is the padded motor cover which has two pull-outs on each side of the motor compartment, that when removed offer two individual seats, (Is anybody following this?) The upholstery is original and suprisingly clean. Is anyone familiar with this model? Was it a production boat? What kind of speed and handling could I expect? Do they put H.D. gears in Alpha's? Are there any precautions I should consider? Thank you for your help in advance. Ray
Good friends of mine had one for a couple of years. Red hull, black fairing. Ran out well with the 350/Alpha they had. BUT, those back seats are NO PLACE to ride if the water is at all rough. Trust me, been there, done that, got the bruises to prove it. It is a good hull, but I just have a big problem with big blocks in front of Alpha drives. Even if it has "heavy duty gears" in it, you will torch it at some point. My boat had an alpha when I bought it, one season, two blown drives, bought a used Bravo.
Yup. Center steering and yes I did take the wheel a time or two. I'd say a small offshore.....call it a sport boat I guess. Not a runabout by anymeans.
Didnt that guy who started that "other" site have one and he put like 6 or 700hp in front of it and it was totally undriveable and he ended up putting the stock 330 back in and selling it??? just a thought, if you were planning on a big build up..........Doug
Ray , Thats a cool set up We looked at that when we were buying our boat 22 was a little tight for us and the three across seating was not made for hanging out. We bought a 1988 Chris Craft 245 limited with a 7.4 and a bravo Tons of room great ride. It,s for sale if you know someone
Ray, How much work is involved to replace the alpha with a bravo? Sos marine has put some big power in front of alpha drives with good success but the boats were light hulls. Let's go look at this boat and after the purchase I'll tow it home for you! From the e-mailed pictures it looks great. Doug
Alpha to Bravo swaps is really quite easy. All you really need to do is drill two extra holes for mounting bolts. X-dimensions are the same believe it or not. You will also need to add the block mounted raw water pump (the alpha has the water pump in the lower unit, the Bravo does not). So you need the pump, belt, and bracket. You may also need a different crank pully if it does not have the slot for the water pump. With a used Bravo assembly, I did the whole thing for just under $2000 installed (this was 7 years ago, I did not do it myself, though now I could as I have learned a lot since then).
