Another Seawater/Fuel pump question.
Ok so I recently rebuilt my mechanical seawater/fuel pump. All new bearings, seals, gear lube etc. now I have lube leaking out of the small weep hole. Anyone know what I could have done wrong? Sorry no photos.
your inner seal -- in which is the oil seal was not depth set correctly or was damaged from the install or is the wrong inner oil seal installed. There is 2 seals there, the outer is the water side seal and the inner is the oil side seal. Also did you change them out to new from the rebuild ?
Also the position of the seals face is important as well. One or more of these answers I posted is your issue
