trim tab issue
Old 05-26-2020 | 05:09 PM
Default trim tab issue
trim tab goes up but not down. With both the dash switch and the trim tab switch on the throttle only hear a click at the pump but it doesn't run. Works fine for up with both switches. Other side is fine.
MIlander is offline
Old 05-26-2020 | 05:21 PM
Your saying trim tab but since you have mentioned throttle, do you really mean power trim?
Trim tabs to me mean Bennett or K planes
AllDodge is offline
Old 05-26-2020 | 05:26 PM
Its pretty simple to test... hop in the bilge with your handy test light and have someone push the switch...green wire is down blue wire is up, got power when you click the switch to the solenoid ? Does the solenoid throw power? are the grounds good???
phragle is offline
Old 05-26-2020 | 06:18 PM
k planes. thanks phragle
MIlander is offline
Old 05-27-2020 | 08:20 PM
Just about sure it is a bad solenoid or a bad connection. Easy fix.
turbo rr is offline
Old 05-28-2020 | 05:36 PM
Sounds like a bad solenoid to me. I went through this same thing last year. I troubleshot it by swapping the solenoids.
87MirageIntruder is offline
Old 05-28-2020 | 08:54 PM
solenoids are cheap, After loosing one last season, I now carry a spare in the tool box...
phragle is offline
Old 05-30-2020 | 02:54 PM
Smile
yup. solenoid . got a spare one too. Thanks for the help
MIlander is offline
