gear lube pump
what are you guys using beside the 1 quart hand pump, Id like to find a 2 gallon arm pump container to fill the drives, so whats out there dont really need a 5 gallon
TIA
TIA
This one has worked out for me along time. Its at the bottom of the link.
Gearcase Testers, Fillers
Holds 3 gallons and does the job. No mess
Not sure, I have IMCO lowers on the Playboy and it works currently. Maybe newer ones are different. Maybe just add a couple of O rings, or add small washer ahead of o ring. Should be easy solution.
The Gear case filler for $252.50 is just an old school metal can sprayer by design.
Mityvac which is well known for repair shop equipment sells pressure pumps that retail over $300 for refilling Transmissions... and it's just a decent pressure pot from a sprayer with a series of adapters..... trick to them all is don't run out of fluid/ add air to the refill
In the shop we had the manual pump on 5 gallon and for remote servicing - it was a good lever sprayer (oil doesn't chew up the seals like chemicals/ fuel will and flows fine in warm weather)...
