Swap old transom assem for new? >
Old 06-05-2020 | 03:31 PM
Default Swap old transom assem for new?
I have a pre Alpha 1979 transom assembly and wonder how hard it would be to replace it with a Gen 1 transom assembly? I hear the engine bell housing needs to be changed to.
Pismo10 is offline
Old 06-06-2020 | 06:00 AM
Ayuh,...... The motor mount spacing changed on the flywheel cover, 'tween the MC-1, 'n Alpha 1,.....
Bondo is offline
Old 06-06-2020 | 06:53 AM
the old inner transom plate could still be used on the new transom assembly couldnt it????
phragle is offline
Old 06-06-2020 | 01:30 PM
So I would need a new flywheel cover to match the modern Alpha Gen 1 Transom assem. Anything else?
Pismo10 is offline
Old 06-06-2020 | 06:56 PM
Anything else?
Ayuh,...... Depends on which motor,.....
Bondo is offline
Old 06-07-2020 | 09:49 AM
Bone stock 1979 260 Mercruiser
Pismo10 is offline
