Help! Excalibur Marine 38 Fuel tank stringer >
Old 06-10-2020 | 08:27 PM
Default Help! Excalibur Marine 38 Fuel tank stringer
Excalibur 1981, Hi I am interested in purchasing one. It has the fuel stringers rotted how much would that cost? And does those stringer have something to do with the hull strength structural wise or is that apart from the main stringers that support the hull?
I need help ! Pleaseeeeee!
Mflorespadi is offline
Old 06-10-2020 | 11:25 PM
It'll probably cost more than the finished boat is worth.
Griff is offline
Old 06-10-2020 | 11:29 PM
My question is are those stringers apart from the main stringers supporting the hull, or are they joint all together?
Old 06-11-2020 | 10:08 AM
Think about it this way if you end up restoring the whole hull which you might it is a 1981, at least you will have a solid boat but at price compared to a new one. I am sure some folks here can give you a quick estimate to what they have spent.
boomer is offline
Old 06-11-2020 | 11:02 AM
Likely just the tip of the iceberg, as others have mentioned. If your looking for an easy patch job consider throwing in some wood boards of similar width to stringers and thru-bolting them to the existing stringers. It is structural. When all the stringers are rotten you will feel the wave travel thru the hull as if it was an air mattress or a wet noodle. Without the structural backing fiberglass will bend.
TexomaPowerboater is offline
Old 06-11-2020 | 12:03 PM
what's your budget to "fix" the boat?
Quick estimate - you will need $50K in reserves to do it all right. That's on top of the purchase price. It becomes a big complex project, with too many unknowns until you start cutting the boat apart and investigate.
That budget can double once you start down the rabbit hole..... Can easily climb into $100K or more, double that if you want something fancy.
Trying to put it into perspective for you.
Some advice - go spend $75K on a nice solid boat and avoid this headache.
frickstyle is offline
Old 06-11-2020 | 02:17 PM
All stringers are structural support for the hull and the chances of that being the only rotted on a 40 year old boat are about.000001%.
Griff is offline
Old 06-12-2020 | 06:33 AM
resurrected's Avatar
If you can do the work yourself, less than 5 grand in material just to do the fiberglass repair. If you can only work evenings and weekend it will take 3 plus years. Once you get it apart you will (and should upgrade hoses, fittings and wiring) add another 3 or 4 grand, if you can do it yourself. Now since your doing that much you will want to upgrade the power, gauges, transmissions, drives and props. 50 or 60 grand, on the low side, if you can do most of the work yourself. My prices may be a little inflated because I'm in Canada and the exchange sucks but you get the drift.
bottom line, have $80,000.00 sitting in the bank to restore it, and don't plan on getting it wet for a long time.
Just my opinion, for what its worth
resurrected is offline
Old 06-12-2020 | 06:44 AM
Indy's Avatar
Member #154
Run
Indy is offline
Old 06-12-2020 | 10:23 AM
read this thread then you decide.....
Back from the Dead; '81 Scarab 38 Resto
Tiki Joe is offline
