Fuel pump (suction) >
Fuel pump (suction)
Fuel pump (suction)
Old 06-15-2020 | 09:15 PM
Default Fuel pump (suction)
I currently have a Mallory fuel pump that apparently is a pusher not a puller so I need to prime it to the the fuel to pump. My question is does anyone have any idea on a good pump that will pull the fuel up to it. Problem I have is it's hard to get mounted under the tank so I run out of fuel when the tank level is below the pump level which happens to be about 1/3 to 1/2 tank. Thanks for any help. It's a carb 502. 415 hp.
riverrunner242 is offline
Old 06-16-2020 | 06:41 AM
Only pump that will pull uphill with any consistency are the old school diaphragm or Weldon Electric.
dunnitagain is offline
Old 06-16-2020 | 07:21 AM
Suggest checking the antisiphon valve on the tank. Its the barbed fitting that the rubber fuel line connects to.
AllDodge is offline
Old 06-16-2020 | 11:11 AM
SB
Yup. ^^^^^
Also, the following based iff my old crusty hardening brain so please double check.....your Mallory could have a gerator type pump which is more efficient on the output side, but less effecient at ‘pulling/lifting fuel up lines’ then the vane type. Vane type is mire noisy then gerators.
As a fyi, many marine companies on carb’d sbc’s and liw hp 454’s that don’t have block provisions for mechanical pumps, use the Marine Carter Electric pumps. They are vane type, again, if I remember correctly.
Hope this helps, and please do a quick study in case my memory mixed up.
SB is offline
Old 06-16-2020 | 11:54 AM
One of the Holley pumps will lift 18", I just forgot if it was the red, blue or black.
ThisIsLivin is offline
Old 06-16-2020 | 01:42 PM
Weldon pumps advertise that they can pull as well as pump, unlike most electric pumps. I used a Weldon mounted on the block and it pumps like a beast.
Baja Rooster is offline
Old 06-16-2020 | 05:47 PM
Rookie's Avatar
I run mallory 140's. This is what I did. I mount the pumps as low as I can in the bilge. I then run a loop in the delivery hose that will keep fuel in the line to allow the pump to prime and create a vacuum.
Rookie is offline
Old 06-17-2020 | 10:26 AM
I did that's been replaced with a regular barbed fitting clear through no valve
Old 06-17-2020 | 08:27 PM
Rookie's Avatar
So you're saying you removed the anti-siphon valve and have issues with it siphoning?
Rookie is offline
Old 06-17-2020 | 08:37 PM
yes correct
