Distributor Won't Spin New Cam Gear >
Old 06-28-2020 | 01:50 AM
Default Distributor Won't Spin New Cam Gear
I just switched to a marine kinetic cam and lifters setup. I have what I believe to be a distributor from a carbed HP 500. Not sure what's needed to verify that. So the gear that cam came with, I tried to install with a new bushing I ordered online, which was part number 1290931. When I started to install gear and pin the distributor got really tight and won't spin at all. The pin is half in. Can I run the distributor without that washer "bushing"?
Dutchboy is offline
Old 06-28-2020 | 02:16 AM
I take it the cam needs a melonized dist gear???
That is a shim and they make they in different thicknesses. You want .010-.020 of end play.
You also need to check dist gear alignment with the cam gear to make sure of correct contact or you'll wear out the dist and/or cam gear.
Griff is offline
Old 06-28-2020 | 02:28 AM
Apparently it's not melonized, it's just parkerized.
So, pull the shim and check the end play?
Dutchboy is offline
Old 06-28-2020 | 03:45 AM
The hole in your new distributor gear may not have been machined in the correct location. I'll have to dig up the info later, but I remember having to drill a new hole in the gear.
Ballistic Beak is offline
Old 06-28-2020 | 05:37 AM
many of the ones I was sent were not drilled correctly. I stopped using cams from them for several other reasons.
Unlimited jd is offline
Old 06-28-2020 | 06:06 AM
That would be awesome thank you
Dutchboy is offline
Old 06-28-2020 | 06:08 AM
If you would could you PM me reasons why? If not I understand, do you happen to know an alternative gear to use?
Dutchboy is offline
Old 06-28-2020 | 01:16 PM
Install the gear w/o any shim and then measure how much end play it has.
Griff is offline
Old 06-28-2020 | 07:15 PM
zero end play.
Dutchboy is offline
Old 06-28-2020 | 07:36 PM
Try a non Chinese gear. if distributor was fine with old gear and no shims with new gear equal zero, throw that gear away
jmo
motor is offline
