Can I convert 496 ho mercruiser to manual controls? >
Old 07-03-2020 | 12:09 PM
Default Can I convert 496 ho mercruiser to manual controls?
New here trying to fix up a boat with a blown motor. I currently have a 232 Baja boss with manual controls and I found a deal on a 496 on Facebook and wanted to see if it was feasible to convert it over? I have the mechanical knowledge just needing a little bit of input.
Moriend is offline
Old 07-03-2020 | 12:52 PM
If your talking about digital controls and wanting to go to mechanical controls, then yes it can be done.
The digital control uses a different TB which does not have a IAC and TPS as the Mech on does. It hass a Throttle control motor which does both. Don't know which serial number motor your looking at so I just grabbed links off the first year model
Here is the Mechanical
https://www.mercruiserparts.com/bam/.../31815/6708/70
Here is the Digital
https://www.mercruiserparts.com/bam/.../31815/6708/80
AllDodge is offline
Old 07-03-2020 | 01:31 PM
[QUOTE=AllDodge;4746622]If your talking about digital controls and wanting to go to mechanical controls, then yes it can be.
thanks for that. Will I need to reprogram the ecm? Or will it be fine?
Moriend is offline
Old 07-03-2020 | 01:38 PM
I would say yes, reprogram
Might also look into the cost of digital throttle control and cable
AllDodge is offline
Old 07-06-2020 | 12:17 AM
Yes
Bcw88 is offline
