Bravo 1 help
Old 07-10-2020 | 08:17 AM
Default Bravo 1 help
Hi, my bravo 1 seized last week I got a rebuilt. There were only 2 gaskets on the drive a rectangular sorta gasket and one around the shift cable. What prevents water from seeping in around the 6 bolts mating point? There was no gasket there
Jase is offline
Old 07-10-2020 | 11:44 AM
the bellows seals the driveshaft. no gasket on bravo drives only 2 round o rings and one formed o ring Alpha drives use a gasket.
actionmarineguy is offline
Old 07-10-2020 | 01:11 PM
I only found 1 o ring around the shift cable. Where is the second?
Jase is offline
Old 07-10-2020 | 01:52 PM
The other round o ring is a thin one where the remote gear lube port mates.
Donzi1979 is offline
Old 07-10-2020 | 01:53 PM
The other seal is a formed o ring for the inlet water passage on the l/h side, that’s it
JaayTeee is offline
Old 07-10-2020 | 05:25 PM
Thanks for your help. But now at the putting the drive back on moment, I checked the coupler to he sure it wasn't screwed up when my old drive seized. I think this is bad , but im not a mechanic. The splines are triangular not square ,Is it usable for another month or needs changed now?
Jase is offline
Old 07-10-2020 | 11:11 PM
Are they splines sharp???
Either way, unless you have time to pull engine and replace the coupler, I'd put it together and use it. Worst case is coupler goes out
Griff is offline
