Need Bravo 1 lower unit built this week in Atlanta >
Old 07-14-2020 | 09:20 PM
aquaforce's Avatar
Default Need Bravo 1 lower unit built this week in Atlanta
Need Bravo 1 lower unit built this week in the Atlanta GA area. Do you know someone? Are you someone who can build my B1 lower this week?
HELP.
My lower unit started leaking again and I don't have time to do anything with it before the Hartwell run. If I can get this one built or find a good used drive for my 97 model Bravos I could make the next two events we planned. seven7zero3six3zero1two7
TIA
aquaforce is offline
Old 07-14-2020 | 10:24 PM
What about buying an Sei lower?
Unlimited jd is offline
Old 07-15-2020 | 12:51 AM
SEI Bravo lowers are $995 with a 3 year no fault warranty. Only negative I've heard about them is the paint does hold up as well as Merc.
https://www.sterndrive.cc/Mercruiser...ower-Only.html
Griff is offline
Old 07-15-2020 | 06:42 AM
aquaforce's Avatar
Yes, I've thought of that too. It may be a viable option given the short time I have to work with.
Old 07-15-2020 | 08:56 AM
aquaforce's Avatar
Update: wow what a pizzer. SEI doen not have any !!!!!! They are back ordered and do not have any idea when they will have them.
I still need a single pick up lower. Help.
Old 07-15-2020 | 09:31 AM
F-2 Speedy's Avatar
Call the bravo shop @ LOTO
F-2 Speedy is offline
Old 07-15-2020 | 11:06 AM
Call George at AADS 517-858-1043. He's turned my stuff around quickly.
ThisIsLivin is offline
Old 07-15-2020 | 03:22 PM
aquaforce's Avatar
That worked well. They also told me my problem in the lower is caused by my upper coming apart and pressing the vertical shaft down causing the leak. Not good. Now I need an entire drive. they have an X series but I'm not at $7K for that one.
So a good used standard bravo 1:5 for 97 model application is what I'm after in time for the Hartwell run by the 22nd. Something that is good enough to run while I build mine.
Old 07-15-2020 | 03:24 PM
aquaforce's Avatar
That was a fax number. Who is AADS?
Old 07-15-2020 | 03:53 PM
F-2 Speedy's Avatar
All American drive service
