New Gen VI 454 Boat needs intake >
Old 07-15-2020 | 08:49 AM
Default New Gen VI 454 Boat needs intake
I just picked up a 29' Sea Ray with a 454ci/7.4L in it. Carbed. It needs a new intake, but before I buy one, I had a couple of questions. Do I want to go with the factory cast iron one for $531 from the boat yard it's stored at or do I want to upgrade to aluminum? This boat will see some salt water time so I was thinking it would be smart for performance as well as corrosion resistance to go with a nice aluminum instead of the factory set up. I'm also going to put a new water/circulating pump on it at the same time.
I just built a Gen VI 454 for my 69 Camaro, so I'm pretty familiar with the platform. Just not on the marine side.
Thanks for any advice.
HawkX66 is offline
Old 07-15-2020 | 09:04 AM
SB
This maybe the same cast iron intake as what merc uses. Double check before you buy, if you are going to buy. Note: GMPP isGM Performance Parts which there are many chevy dealerships that are part of this. Yoo may have one nearby if that matters to you.
https://paceperformance.com/i-625541...et-flange.html
SB is offline
Old 07-15-2020 | 09:14 AM
Price is definitely much better, but I thought marine intakes flowed differently than auto intakes? That looks like a regular car BBC intake. Am I off in my thinking?
HawkX66 is offline
Old 07-15-2020 | 09:20 AM
F-2 Speedy's Avatar
The one SB posted is for a marine app, see the 4 additional bolt holes, auto wont have them
F-2 Speedy is offline
Old 07-15-2020 | 09:51 AM
SB
Then post up what your intake looks like and if it's oval or small oval or what have you and then we'll see.
SB is offline
Old 07-15-2020 | 10:00 AM
I don't have it handy to take a pic, but it's just a stock Mercruiser BBC intake.
Which four bolt holes are you talking about? Mounting holes would be the same wouldn't they? What I'm concerned with is also the flow characteristics. A boat is "always driving uphill" unlike a car so the intake flows differently.
Also, my other question really is about aluminum performance intake versus cast iron.
Thanks.
HawkX66 is offline
Old 07-15-2020 | 01:01 PM
Active Streak: 30 Days
Thanks.
Flows the same as a car intake. Difference is most GM intakes have a brass seal around the water ports. Depending on the model number and serial number of your engine, will determine the right original style intake. The picture does not show the 4 holes, but what he is referring to is there are 4 extra holes on the carb mounting flange for the 2 different bolt pattern carbs used, Quad spread bore and Weber square bore.
Helmwurst is offline
Old 07-15-2020 | 01:18 PM
Ok. Quadrajet or Holley 4150 mount style. Really nothing to do with marine application or not. Thanks.
If I can run a car intake, I might as well run one of my intakes that I already have. Cast iron also only has the quadrajet bores.
So riddle me this... Why would someone want to spend $500+ on a cast iron intake when they can run something like an Edelbrock dual plane low rise that will flow much better and produce a better torque curve?
https://www.summitracing.com/parts/edl-7561/make/chevrolet
HawkX66 is offline
Old 07-15-2020 | 01:40 PM
https://www.summitracing.com/parts/e...make/chevrolet
There are many parts that are the same - marine vs automotive. Marine dealer $$$$$. Automotive dealer $-$$.
GETTINBYE is online now
Old 07-15-2020 | 08:07 PM
The Edelbrock Performer RPM Air-Gap or the Weiand Stealth are both pretty good intakes. The next restriction is the factory exhaust.
