paint for graphics
Old 11-12-2002 | 12:36 AM
totalmp's Avatar
Default paint for graphics
I am prepping my 36' Cig for paint. Which is the best to use for base and graphics. I would like a paint that I can clear over. Any help is greatly appreciated.
Stephen
totalmp is offline
Old 11-12-2002 | 06:39 AM
glassdave's Avatar
Neno the mind boggler
i use PPG's DBC base coat with thier concept 2021 clear and have great luck. very easy to work with, good tape times and is very durable. if you are doing a large amount of graphics the high solids base coat/ clear coat systems are the only way to go. most paint manufacturers (PPG, dupont, BASF, etc.) offer very high end products and it comes down to which ever one you feel most comfortable working with. not sure there really is a "best" one these days. good luck
i did this one in concept base/clear. did all the graphics on both sides in one day and did the deck the next day than buffed the whole thing out the day after that.
glassdave is offline
Old 11-12-2002 | 09:15 AM
totalmp's Avatar
Thanks Dave, do you have any pics of the boat during the paint process. This will be the biggest boat I've ever painted. Any help is greatly appreciated.
Stephen
totalmp is offline
Old 11-12-2002 | 09:26 AM
Audiofn's Avatar
Charter Member #232
PREP PREP PREP. PREP is the most important thing. Make sure you sand it all to the manufacturers spec and do a good job. Do not get lazy at the end of the sanding and rush it. To help out with this when I did my boat I started on one side and worked around. Then the next day I worked in the other direction
I have had real good luck with Glassurite (sp) Paints, these are made by BASF, on cars. The PPG is also excelent as Glassdave has said. Good luck
Jon
Put your best foot forward!
Audiofn is offline
Old 11-12-2002 | 10:35 AM
glassdave's Avatar
just like audio said . .prep prep prep. it is most times easier to splt the paint process into top and sides seperatley. i prefer to do the sides first and deck last. although this is sometimes dependant on choice and complexity of graphics. one of the hardest things is reaching the middle of the deck with the gun, for this i have a custom gun that gives me about a 6 foot reach alowing me to paint boats oer 12 foot wide ( like those damn ocean express cats ) this is the only pic i have of the boat in paint process that i can find. feel free to call me if you would like a better explanation of tips to make it easier. my cell # is 419-461-1484 call after 9:00PM ohio time (free night an weekend cell time )
Old 11-12-2002 | 10:46 AM
glassdave's Avatar
heres one of the deck. all the logos and cig script on this boat are painted on under the clear. i use vinyl spray masks to make this easier. all the stripes and flags are free hand taped and tailored to the boat. if you need any spray masks contact ryan beckley on this board his buisness is kinetic animation ( i think he is in the links section) he is very good and very resonable he will have anything you need.
Old 11-12-2002 | 12:19 PM
later's Avatar
Glassdave
what is a vinyal spray mask and do you apply a primer before the colors or go right over the gel?
later is offline
Old 11-12-2002 | 02:07 PM
glassdave's Avatar
later- a spray mask is basically a sheet of vinyl that has the letters or logo cut out on it ( kind of the opposite or negative of just the letters). you apply the sheet and spray your colors than remove the sheet leaving the painted logo. saves a ton of time. before vinyl plotters i used to do this stuff by hand. as far as primer goes i only use it when there is alot of surface work. for new boats i just use a sealer like DP48 or an adheason promoter. also on new boats i still lay down a gel matched white base coat before graphics than clear. i never just clear over gel, i know it has been done im just not a big fan of it, habit i guess.
Old 11-12-2002 | 06:00 PM
MrCIG's Avatar
Charter Member#330
Nice work Dave!!!
MrCIG is offline
Old 11-12-2002 | 06:09 PM
cig1988's Avatar
Does anyone know where I can get the spray mask for the cigarette logo ? I had the contact in Florida several years ago but lost it. I used imron and cleared over the color only. Worked like a charm and still looks like the day i sprayed it.
cig1988 is offline
