Whippled 509 quits over 1000 rpm >
Old 08-01-2020 | 09:59 AM
bigboat28's Avatar
Default Whippled 509 quits over 1000 rpm
Twin whippled 509s. Port motor starts, idles and shifts fine but once you push throttle over 1000 rpm it coughs, sputters and dies instantly or sometimes it may lose rpm down to 3-400, catch itself and slowly come back up to idle. They have new cap, new rotors, swapped fuel pumps, swapped coils and swapped ECMs. They have thrown no trouble codes other than low voltage on the throttle body sensor. Also had the fuel tank drained and cleaned. All fuel filters are clean or new. Any ideas?
bigboat28 is offline
Old 08-01-2020 | 10:35 AM
I would start by checking fuel pressure
underpsi68 is offline
Old 08-01-2020 | 10:42 AM
F-2 Speedy's Avatar
you can pull the IAC and cycle the key on and off to see if its functioning normal..........I had one do similar issues engine would die when put in gear under load, swap the IAC's see if it follows...........what blowers are these 3.3 ?
F-2 Speedy is offline
Old 08-01-2020 | 10:57 AM
bigboat28's Avatar
Fuel pressure 45-50
2.3 whipples
Old 08-01-2020 | 11:00 AM
F-2 Speedy's Avatar
Originally Posted by bigboat28
Fuel pressure 45-50
2.3 whipples
seems high, is that what whipple calls for ? to much fuel pressure injectors wont fire correctly
Old 08-01-2020 | 11:04 AM
bigboat28's Avatar
Think so or so I was told
Old 08-01-2020 | 08:08 PM
they'll fire just fine up to 70psi,i tested mine up to 100psi,had to tap start them to fire,but once going,they did fine.I was just testing them to make sure they were fine.
sutphen 30 is offline
Old 08-01-2020 | 08:12 PM
are you talking about the throttle position sensor,,if voltage is low,need to find out what connection is bad.
Old 08-01-2020 | 08:16 PM
bigboat28's Avatar
Yes throttle position sensor
Old 08-01-2020 | 08:39 PM
I'd say you have a bad sensor or a sensor ground was missed.
