Marine electronics installer near LOTO
Looking for a good stereo and marine LED guy or shop around the LOTO area (excluding waves & wheels) I can trailer the boat but want to be close enough to the person that's doing the work to check on it. So maybe up to another hour away from LOTO or Jeff City/Columbia area. I am looking for someone or shop that is meticulous I am wiling to pay for quality work I am not willing to pay for high quality work and get shiiite!
- Need a new head unit which will require a slightly bigger cut out for the new Fusion head units
- Wring is not right someplace possibly the grounds are not common or some capacitors need to be installed - loud pop when turning the head unit on, whining noise when operating the trim tabs, rear speakers seem to cut out so amplifier wiring or amp may be hosed
- Marine LED's - Two shadow casters on the transom don't work these are factory installed and have a dash switch
- 4 Bluefin LED's inside the boat work but use the what I believe is the Bluefin controller and key fob - these are non factory and were installed at some later date in the boats life
- 2 Bluefin LED's on the transom right next to the shadow caster LED's these work but I think the marina lost the key fob what I want to do is get a Shadow Caster 4 zone LED controller to control all the Bluefin LED's
I did get a reply but it was just a quote of what I sent you last no new comments or questions came through I will send you my number if its easier to text or call
Not my experience with Justin in any of the 3 projects I've done with him over the last decade. But then again, I guess everyone can have a hiccup project now and then. Mid Missouri, particularly the LOTO area is hard enough to find competent contractors for almost anything, but that's mainly for non boating stuff. Not only has he done an outstanding job on all 3 projects of mine, he comes through on service after the project, no questions asked! My experience with him is A+++.
