Spark Plugs and Gap? >
Old 08-17-2020 | 10:27 AM
Default Spark Plugs and Gap?
i have a 502 that was rebuilt and added a Side Whipple. What is a recommend spark plug and should i gap differently because it is now running boost?
flawlesson24z is offline
Old 08-18-2020 | 07:56 AM
The biggest question is what will your ignition support? Most aftermarket ignition systems will give you a recommended gap for the boost you are running.
ThisIsLivin is offline
Old 08-18-2020 | 08:12 AM
stock ignition .025-.028"
cd ignition .030-.035"
sutphen 30 is offline
Old 05-24-2021 | 01:29 PM
I have a question . I’m running a 598 with a performance distributors marine 7000 series. Just called them and they said I can open the gap to what they recommend, .050-.055. It’s naturally aspirated, and I have the gaps set to .035. Is it worth opening it up?
Pulse74 is offline
Old 05-24-2021 | 01:37 PM
SB
To just above, .035” is fine, unless you want to eat dist caps/rotors, wires, coils , and nore likely to misfire.
Your mileage may vary.
SB is offline
Old 05-24-2021 | 03:10 PM
D.U.I. Distributers recommend.055 and most of us lost a good deal of top end with that. Pulled it back to .038 and all was good again. I’m no engine builder but just by crowd sourcing info from the internetz that .035-.040 seems to be the widest to go even with hipo ignitions. Results may vary.
Baja Rooster is offline
Old 05-27-2021 | 03:33 PM
Glad you said that. I never noticed the discussions about the DUI gaps. I just put in plugs yesterday and did .055. I just switched em to .038 and gave it a start, seems smoother on choke any way.
Going for a little ride tomorrow, but the weather is supposed to turn bad Friday PM through the holiday.
NHGuy is offline
Old 05-27-2021 | 05:42 PM
SB
I talk about it all the rime. Just like I did just above.
Oh well.
SB is offline
Old 05-27-2021 | 06:10 PM
Oh well.
You’re always on point so WHAT spark plugs should I be using right about meow???
