Oil pressure loss >
Oil pressure loss
Oil pressure loss
Old 09-13-2020 | 03:37 PM
Default Oil pressure loss
Hey guys!
So here’s the concern- I did my first WOT pull on a new motor yesterday, dropped back down into the no-wake and my oil pressure at in gear idle was hanging around 3-5 pounds.
A little background... there’s about 2 hours on this engine. It’s a 468, 4 bolt, cast crank, flat top pistons, Comp 262/268 112° Flat tappet cam, roller tip rockers, double valve springs on peanut heads.
I’ve got Sierra 25-40 oil in there with 2 bottles of Lucas break in zinc additive. Did the cam break in at 2500 for 25 minutes.
My WOT run was under 7 minutes with 60 PSI at 4600, 155°. I tied up for an hour after, then when I went to trailer up I had 40 pounds at idle headed back to the dock. No hose blow ups in the engine space, cooler, hoses & remote filters are all happy.
Any ideas what happened there?
Thanks for any input!
The Violator is offline
Old 09-13-2020 | 04:17 PM
155 WATER TEMP OR oil TEMP? HUGE DIFERENCE.
GLENAMY 242SS is offline
Old 09-13-2020 | 04:19 PM
155 was water temp while under throttle.
Old 09-13-2020 | 04:26 PM
Verify with mechanical gauge
liberator221 is offline
Old 09-13-2020 | 05:14 PM
What oiling system/oil cooler? Your oil temps were likely thru the roof and thinned oil to a much lighter weight than 40w.
Ryan00TJ is offline
Old 09-13-2020 | 05:25 PM
Is your oil cooler new or from previous motor?
Chris
Blueabyss is offline
Old 09-13-2020 | 05:51 PM
SB
Remove and Cut filter apart before running it again with mechanical gauge , if nothing found in filter.
SB is offline
Old 09-13-2020 | 08:14 PM
Speaking of the filter, what brand and what number did you use?
Baja_260 is offline
Old 09-13-2020 | 09:10 PM
Sounds like your oil cooler is undersized. Some oil filters have a paper medium non friendly for marine use that swells and chokes the system, but my guess is your oil got cooked.
Baja Rooster is offline
Old 09-13-2020 | 10:07 PM
Thanks for all the input!
Sounds like a bigger cooler is in order.
I’m just running an OE Merc cooler then taking off with -10 AN hose to a Deralé dual remote filter housing.
I’ve just got some low-end O’reilly filters on there now but will switch to Wix racing tall filters after I change out the break in oil.
