Which valve spring compressor?
Which valve spring compressor are you guys using?
I tried this one, but it’s too small, too flimsy and the lever is too short. I need something stronger with a better leverage for double springs in my big block heads.
Useless
Useless
I have this one and has worked flawless for me. My current springs are 250/700lbs. Doesn't flex at all.
https://www.summitracing.com/parts/pro-66764
I have a green one made by Goodsen. Wonderful tool
https://goodson.com/collections/valv...ing-compressor
Pneumatic valve spring compressors are nice if you have enough work to justify the cost. Assembly/disassembly time is much quicker and easier.
MTI Valve Spring Compressor
