Bravo 3 Transom Assembly
Old 09-23-2020 | 01:49 PM
Default Bravo 3 Transom Assembly
What's the general consensus on the transom assembly seal when it comes to needing sealant? I've seen comments from dry or needing a coat of grease to needing 4200. I know 4200 wouldn't hurt, but is it really necessary? The transom is in excellent condition and flat. The assembly is new Mercruiser.
HawkX66 is offline
Old 09-23-2020 | 02:20 PM
Knot 4 Me's Avatar
Buddy had one done a couple years ago. Factory put original in dry and it was still good with no signs of leaking after 15 years. New assembly/gasket was put back on same way. Like your boat his transom was nice and flat.
Knot 4 Me is offline
Old 09-23-2020 | 02:45 PM
The only thing that has me wondering is the material the gaskets are made of. The one I removed seems to be rubber where the new one is foam. I coated it with grease, but now I'm second guessing before I put the motor back in whether I should use 4200 sealant.
HawkX66 is offline
Old 09-23-2020 | 03:02 PM
Put it on dry
Grease is not good and can cause the seal to break down depending on what the gasket is made of.
AllDodge is offline
Old 09-23-2020 | 04:04 PM
Originally Posted by AllDodge
Put it on dry
I already applied a little grease and installed the assembly. The gasket is foam like a cars trunk gasket.
HawkX66 is offline
Old 09-23-2020 | 04:14 PM
I installed dry in 2018 and no leaks since.
ancho is offline
Old 09-23-2020 | 04:25 PM
Remove, clean with dawn dish soap
Agree it appears to be like a truck gasket, but I also installed new and dry some years back
AllDodge is offline
Old 09-23-2020 | 09:39 PM
Never put a thing on one. Grease/gas/oil breaks down rubber.
tmmii is offline
Old 09-23-2020 | 09:42 PM
Agreed grease is a bad choice. What is the benefit?
I did mine a few years ago, and added a very thin film of silicone to the edges of the assembly (not on the seal itself).
1MOSES1 is offline
Old 09-24-2020 | 06:00 AM
What about marine lithium grease? It's not the same as regular petroleum wheel bearing grease. Just trying to figure out if it's really necessary to pull it back off. Thanks.
Edit: I think I answered my own question. It's still petroleum based so I guess I'm pulling it off. Thanks for all the responses guys.
Last thing... fwiw, the new seals aren't really rubber, but a foam like seal it seems like.
HawkX66 is offline
