Calling all 496 gurus.  alarms after cranking, >
Old 09-26-2020 | 04:05 AM
Default Calling all 496 gurus. alarms after cranking,
I have a 496 in my Sonic which alarms 2 beeps per minute only after start up. It does this immediately upon start up. Shows nothing on Rinda scan tool.
The engine starts and runs sounding ok.
I have read in the PCM 555 troubleshooting manual that cam position sensor will only alarm after cranking the engine.
So I have been pursuing the cam sensor, unfortunately that’s not so straight forward with 2003 496 as it require a modification which includes new cam sprocket, timing cover and current sensor to upgrade to current sensor style as the original one is obsolete.
I did try one cam sensor from Summit Racing but I still get the alarm (which also derates power to 90%).
I have also found a direct replacement for my sensor part number from Germany but the engine will not start and just backfires with that in it.
Just wondering if anyone knows are there any other alarms on 496 that will only alarm after cranking the engine? Or any other ideas?
I have also replaced water pressure sensor but would disregard water pressure in any case as it alarms to quickly after starting for it to be that.
simon1401 is offline
Old 09-26-2020 | 08:34 AM
We just had one do that last weekend. It was a bad iac. It was actually burned up at the connector.
flat rate is offline
Old 09-26-2020 | 04:40 PM
The 2 beeps should show a code, or at least an error on a scanner, hence why its beeping
Can be several things, see list below
AllDodge is offline
Old 09-27-2020 | 04:42 AM
did that give any symptoms? Mine runs perfectly except alarm beeps and power limited to 89%
Old 09-27-2020 | 08:26 AM
[QUOTE=AllDodge;4759007]The 2 beeps should show a code, or at least an error on a scanner, hence why its beeping
Thanks for the info. Re the scanner, definitely no codes other than those which are always on there. I.e. pitot, fuel level, trim etc. I think I have read somewhere that the early PCM555 models didn’t show cam position fault codes, although that maybe a red herring!!!
I will check again through those other sensors on the list. I’m beginning to wonder if it could be ECM issue.
Old 09-27-2020 | 09:25 AM
Check voltages, 5V and 12V
AllDodge is offline
Old 09-27-2020 | 09:56 AM
You have to know what your looking for on the scanner. The information might be there but you might not seeing it. Look at all sensor values, iac position, voltages etc.
If only they was a 496 guru on the site...... sorry I had to. 😁
underpsi68 is offline
Old 09-27-2020 | 11:22 AM
5 and 12 volts all good on scan tool
I saw this post by BUP which may explain why I cannot see codes on scan tool.
Merc PCM 555 with software prior to level 091that has a problem and or bad crank & cam position sensor will not set a fault.
With level 091 software if the camshaft position sensor is completely bad or has bad circuit in which causes a signal not to be sent to the PCM, the engine will backfire and not start, if this happens stop cranking and try to start again. keep trying to restart. If the engine does start and two beeps from the audio warning takes place asap it can be more than likely be a bad bad cam PS. It should set a fault code if you can run the motor for 30 seconds straight..
I don't have idle starting issues, backfire or any other give aways. But have decided to order a new 496 cam position sensor update kit. Its a bit of a pain to install because I will have to lift the engine and strip out the front end to replace the cam sprocket and timing cover but I have reached the point of going round in circles. It will take a week or so to arrive from US as I'm in the UK but I will let you all know how I get on.
Any other ideas in the meantime gratefully received.
Agreed with having to know what to look for on scanner. So I can confirm no codes but alarm 2 beeps pm, no voltage issues, any suggestions further to that welcome.
Thanks so far👍
Old 09-27-2020 | 12:08 PM
BUP sells direct replacement cam sensors i believe. Save you all the hassle.
Old 09-27-2020 | 12:25 PM
Ah that sounds good, How do I get hold of him? I googled earlier but should have guessed to ask here first.
