thru hull fitting removal
Old 09-28-2020 | 01:55 PM
Angry thru hull fitting removal
greatings
I have a broken thru hull plastic fitting that I need to be removed. Can someone tell be if I turn the drives to the side if I can remove this fitting without taking the gimble ring out. There is room just not a lot .I have bravo1 drives w/ 454 mercruiser motors
scarab33 is offline
Old 09-28-2020 | 05:15 PM
Originally Posted by scarab33
greatings
Would help quite a bit if you posted a pic for reference. Thanx.
smashm is offline
Old 09-29-2020 | 01:28 AM
You are going to need to be more specific about what fitting you are talking about
Griff is offline
Old 09-29-2020 | 06:56 AM
Agree more info, but think its not a thru hull but the plastic piece which is used to hold the hose on the bell housing or transom assembly end
AllDodge is offline
Old 09-29-2020 | 07:04 AM
Sorry - it is the exterior gear lube plastic fitting that connects the lube hose: which used to be brass, but since I got the both gimbals changed 4 years ago they are now plastic. What broke is the male part of the fitting going into the lube hose
scarab33 is offline
Old 09-29-2020 | 07:45 AM
You need to pull the bell housing and maybe even the motor
Could replace the plastic one with the brass one 22-18922 and 22-18923
AllDodge is offline
Old 09-29-2020 | 01:35 PM
AllDodge, How does the brass one seal without o-rings sealing the water from coming through the transom assembly? I have never seen the brass one but like the idea after dealing with the plastic ones.
Donzi1979 is offline
Old 09-29-2020 | 01:44 PM
It does use a O ring item 2
https://www.mercruiserparts.com/bam/...30967/1943/330
AllDodge is offline
Old 09-29-2020 | 03:31 PM
Hey,
To my understanding you cannot switch out the plastic for brass ,theses are new gimbals which use plastic fittings. my old gimbal were brass,I did switch out the lube tube fitting inside the transum with a little twisting of my body but now the outside fitting broke at the tube fitting .Motor removal is not necessary but I am asking if someone did remove this thru hull fitting without removing the bell housing because I can get my hand in there but its tight
scarab33 is offline
Old 09-29-2020 | 03:44 PM
Hey,
ive done quite a few of them. Turn the wheel all the way to port with the drive trimmed down and you can get right at it
Unlimited jd is offline
