Flush Kit
Old 10-06-2020 | 10:01 AM
Default Flush Kit
I just bought a 2009 Checkmate 270 Convincor with a 496 HO. Will the Merc flush kit 898235A02 work on this motor? I've seen adds that say it will if it's a non EC motor. Don't know what that means. Thanks!
Darryl1969 is offline
Old 10-06-2020 | 10:25 AM
Rookie's Avatar
I'm assuming EC means enclosed cooling. That means it has heat exchangers with antifreeze running through the engine.
Rookie is offline
Old 10-06-2020 | 12:39 PM
I have a flush kit on mine with closed cooling so all I’m flushing is power steering cooler, heat exchanger, and exhaust risers. I do run boat on muffs first to flush outdrive too but then I hook to the flush kit. If it’s causing any problems, I’m not aware
Ratty206ls is offline
Old 10-06-2020 | 01:35 PM
Just found out it means emission controlled.
