Twin trs Saginaw power steering help >
Old 10-07-2020 | 07:25 PM
Default Twin trs Saginaw power steering help
Need some pointers guys. I have an old spectra 32 that I'm finally getting ready for sea trials. Problem I'm having is that my power steering ( still the original Saginaw valve setup ) is not giving any assist. I seem to have fluid going through the valve but doesn't seem to be much. I have loosened the hardline at the cylinder and I could see fluid running out but not much. Does anyone have any trouble shooting experience with this?
killfast1 is offline
Old 10-07-2020 | 07:29 PM
Also, was wondering if the newer valves can be used on the trs transom plate
Old 10-07-2020 | 10:46 PM
The valve is the same as a 59 Impala and up to 82 Corvettes, rebuilds are available. Check your cable length to be sure the valve is moving the correct amount. There is also a psi test that can be done to verify, check a Mercruiser TRS manual for instructions.
1Zoom is offline
Old 10-08-2020 | 12:48 AM
Thanks. Ill check if I can fincann online manual
Old 10-08-2020 | 01:14 PM
Steering is fixed. Seems something in valve was stuck. When I undid the cable based on troubleshooting steps. I moved the valve. The drives moved slow then a bang and they moved correctly.
Old 10-09-2020 | 11:10 AM
phughes69's Avatar
I had the exact same thing happen on my Scarab 300. The boat sat out of the water for a year with the PS lines disconnected. Steering was slow and hard until I had the engines up to speed then just like you, bang it loosened up and worked the way it did before. I think it may have been a air pocket or something but all seems normal now.
phughes69 is offline
