Go Back  Offshoreonly.com > Owners Forum > Donzi
38zr interior >
38zr interior
38zr interior
Old 10-18-2020 | 06:52 PM
JLS
Default 38zr interior
Has anybody ever replaced the engine hatch vinyl and had to remove the plexiglass cover on the inside? Looks like they siliconed it in and a pain to remove. Any ideas would be helpful. Thanks
does anyone know who made the donzi interiors?
JLS is offline
Old 10-23-2020 | 06:34 AM
8Ballclan's Avatar
JLS ...
I came across this on one of the Donzi sites -- Premier Performance Interiors in Sarasota FL www.ppi-fl.com did a lot of the interiors when the ZXs and ZRs were built.
FWIW, I have also come across info suggesting that some work was done in house as well.
good luck!
8Ballclan is offline
Old 10-23-2020 | 10:37 AM
I actually just pulled my entire interior out. The plexiglass was kind of a pain but it came out, in pieces though. It was spray glued onto a type of fiberglass backer board which was then adhered to the hatch with some type of adhesive like a 3m 4200/5200 or some construction adhesive. I used a hammer and wonder bar to pry the plexi off slowly and worked my way from the front to the back. Crappy part is about half way back the fiber board starters coming with it so now I have to find a replacement for that as well.
IGetWet is offline
Old 10-26-2020 | 12:21 PM
JLS
Took it apart this weekend and found the same Issue, Was able to get Plexi off but backer board came off in little pieces. Did you ever figure what that backer board was exactly?
JLS is offline
Old 10-26-2020 | 03:27 PM
No I have not yet. Put her in storage for the winter and haven’t been back over yet.
IGetWet is offline
Old 12-12-2020 | 06:23 AM
Removed the vinyl and foam from the sun pad. I think I’d like to replace the black plastic base of the sun pad. Anyone know what that material is and where it can be bought?
IGetWet is offline
