Dyno- 600hp 454's
Old 11-14-2002 | 11:42 AM
Crazyhorse's Avatar
Default Dyno- 600hp 454's
Hey, Kaama's got dyno sheets from his 600hp 468 engines. We need to talk with him about those engines.
Crazyhorse is offline
Old 11-14-2002 | 11:52 AM
dyno's Avatar
Charter Member #655
need a bigger cam and better exhaust........and some help from JimV
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 11-14-2002 | 05:57 PM
ragtop409's Avatar
Ya give us some dirt. Whats in side of them. Exhaust and ignition for the dyno pulls. Charlie
ragtop409 is offline
Old 11-14-2002 | 06:52 PM
Crazyhorse's Avatar
KAAMA said he had the Merlin oval-port heads (2.30 intakes, 1.88 exhaust) solid roller cams and Torqer intakes. We could sit here with Desktop Dyno 2000 and run some scenarios.
Old 11-14-2002 | 07:02 PM
dyno's Avatar
Charter Member #655
Get to it!!!!I see you lurking Mark what were the piticulars???
dyno is offline
Old 11-14-2002 | 07:11 PM
KAAMA's Avatar
No---not Torker intakes. Those 468's had the Dart intakes on them that are now on my 540's. But Crazy is right about the heads-----Merlin oval ports bowl ported with short side radius work. They had Dominators 1050 carbs----heck I don't even use those on my 540's, 9.5 comp ratio, Crower solid roller cams 244*/254* on 110* lobes, Stellings full length tube headers, and the cylinders were "bore notched". Apparently, the Dominators made 35 more horsepower over the 850cfm carbs---but I wasn't there to see the comparison. But I do have the dyno sheets for both engines. With the Dominators both engines made 600hp @5500rpm w/37* of total timing....not too bad for a pair of naturally aspirated 468's!
KAAMA is offline
Old 11-14-2002 | 08:14 PM
RLW
I still don't know what "bore notched" means.
Can anyone explain?
I thought it pertained to a "Stroker" motor.
RLW is offline
Old 11-14-2002 | 09:06 PM
Bore notching is when you cut the eng block above the top ring of the piston to the area where the valve is to let more air flow into the cylinder.
fstboater is offline
Old 11-14-2002 | 10:01 PM
RLW
Thanks Fstboater!
RLW is offline
RICHARD CUNY
21
03-21-2008 06:22 PM
ls1nova
12-08-2007 09:49 AM
BLAZE
10-06-2007 04:30 PM
RJBBC
Checkmate
64
08-19-2005 05:27 PM
Semper Fi
22
12-27-2004 04:56 PM
