Oil pan recommendation >
Old 11-17-2020 | 11:25 AM
Default Oil pan recommendation
I’m building 540s with 3.3 Whipples and looking for oil pan recommendations.
lucky cat is offline
Old 11-17-2020 | 11:57 AM
GPM
Just a though
OFFSHORE
Designed for multi-engined race boats or deep V hulls that require an under engine mounting cradle. Built from heavy duty 16 gauge steel to withstand severe racing conditions. Baffling designed for 100% oil control, has provision for oil temperature sender and dual watertight, screw-in dipstick locations for mounting either side.
Mk IV / V & Gen VI will fit 4 1/2" stroke with most aluminum rods.
Pan Capacity is 12 Qts. Plus Filter
5" Front,9 1/2" Deep Rear Sump 396-454 Mark IV ('65-'90) 31560t, Milodon.
GPM is offline
Old 11-19-2020 | 10:19 AM
Thanks GPM
Old 11-19-2020 | 11:57 AM
This would be cheap 11qt pan with tray and scraper
https://www.jegs.com/i/JEGS/555/50236/10002/-1
JaniH is offline
Old 11-19-2020 | 01:13 PM
articfriends's Avatar
I would avoid that pan or anything built similar, I dynoed a 540 WITH a whipple 3.3 with that exact pan (customer picked it and supplied it), worked good on the dyno BUT the metal was very thin, where it was welded it was even thinner and I am almost certain over time it WILL crack. Was very flimsy and thin, Smitty
articfriends is offline
Old 11-19-2020 | 02:16 PM
do you have any recommendations Smitty?
Old 11-19-2020 | 04:02 PM
I have a Dan Olson on my motor. He makes a good pan.
fbc25el is offline
Old 11-19-2020 | 04:08 PM
Get the deepest pan possible (14qt) so you don`t aeration of the oil and the falling oil pressure that comes with it .
https://www.cantonracingproducts.com...ystem+Capacity
That`s my suggestion.
I have the above pan , it`s been welded on without issues , it`s is well constructed
ICDEDPPL is offline
Old 11-19-2020 | 05:13 PM
Give Teague Custom Marine a call they have good products and don’t deal with crap...
bigfarmer is offline
Old 11-19-2020 | 05:14 PM
Drake22.250's Avatar
Steffs make a nice pan also, check them out.
Drake22.250 is offline
