Bravo upper case vs. XR case >
Old 11-20-2020 | 08:24 AM
Default Bravo upper case vs. XR case
Is a stock bravo one upper case the same as a Bravo XR upper case? Can the internals be swapped from one to the other?
Satisfaction is offline
Old 11-20-2020 | 10:42 AM
Mbam's Avatar
Offshoreonly Advertiser
Short answer - no & no
Mbam is offline
Old 11-20-2020 | 12:25 PM
The X cases are larger in the snout where the pinion bearings are housed
JaayTeee is offline
Old 11-20-2020 | 01:43 PM
You can install an XR upper on any standard B1, 2 or 3 lower
AllDodge is online now
Old 11-22-2020 | 11:58 AM
The case is different but you van use XR gears in a standard Bravo Case!
RBeyer is offline
Old 11-23-2020 | 06:12 AM
you have to contact max machine worx,they have a new yoke that lets you use the xr gears in a standard case.I did this 13-15yrs ago,and in an old style case no less.
sutphen 30 is offline
