How to delete the trim sender wiring thru a Bravo transom assembly & seal the hole? >
Old 02-07-2021 | 11:59 PM
Default How to delete the trim sender wiring thru a Bravo transom assembly & seal the hole?
I am rebuilding my Bravo transom assemblies and I have them all apart for paint. I have mechanical trim indicator cables on my boat but the transom assemblies have the standard indicator wiring in place. Is there a way to remove the wiring and seal the hole that would be left by removing the wiring/rubber plug that’s in there now? Thanks
Steve888 is offline
Old 02-08-2021 | 07:43 AM
There might be a plug but it would be easy to just cut the wires and leave the original plug. I would leave maybe an inch on the outside
AllDodge is offline
Old 02-08-2021 | 08:03 AM
if everything is off the boat,have the hole welded up.
sutphen 30 is offline
Old 02-08-2021 | 11:39 AM
Thanks for the reply. I was planning to go that route, but these are the original transom assemblies from my 88 Bullet so those rubber pieces are 32 years old so I am a little concerned about them.
Steve888 is offline
Old 02-08-2021 | 11:42 AM
Thanks for the reply. I have one assembled already so that would cause some extra work but it’s definitely a good idea.
Steve888 is offline
Old 02-09-2021 | 05:05 AM
19-861492 trim sender hole plug
motor is offline
Old 02-10-2021 | 10:09 PM
Thanks!
Steve888 is offline
