502 impeller
I’m wanting to change my impeller on my 502 mag mpi, looks like a straight forward job apart from the top bolt of the bracket looks like it will be obstructed by the circulation pump inlet? Do I need to remove the circulation pump or is there I way around it? I’ve searched but come up with nothing.
cheers
cheers
On my 1998 (serpentine belt) 502, I remove the nuts holding the pump to the bracket, then loosen the bracket to create some slack. I then drop the pump off the bracket to work with the hoses. Reassemble in reverse. It's helpful to use a lubricant on the hoses in order to make removal easier (especially the wire-reinforced inlet hose).
It really depends on what year engine you have. On my 2000 502 mpi's, I just loosen the hose clamps and then remove the bolts holding the sea pump to the bracket. Then just pull the entire sea pump out and install new impeller on a bench. Re install in reverse order. It is the same for 1998+ https://www.mercruiserparts.com/bam/...31912/4854/150
1997 cool fuel with V belts, I would pull the sea pump pulley and do it the same as above https://www.mercruiserparts.com/bam/.../31910/2336/19
1997 and earlier with VST system and V belts pretty straight forward and same as 1998+ except you need to disconnect and reconnect fuel pump line. You should also change the gear lube inside it. https://www.mercruiserparts.com/bam/.../31910/2336/18
No reason you should need to remove the bracket on any of them unless its too hard to get to the sea pump to do one of the above.
