Merc 350 MAG MPI 0M300000
Old 02-20-2021 | 05:40 PM
Default Merc 350 MAG MPI 0M300000
I have a 2003 Merc 350 MAG MPI 0M300000 Bravo that I am prepping to do head gaskets on. My question is, what automotive engine does this engine cross reference with? (yes I know not use steel head gaskets)
Thanks in advance for any help given.
AtomicFrawg is offline
Old 02-20-2021 | 06:06 PM
A chevy 350. What do the valve covers look like, hold down around the parameter or 4 in the middle ( vortex) ?. Vortex were worth 55 hp if I remember correctly but the intake manifolds are different.
carnutsx2 is offline
Old 02-20-2021 | 07:12 PM
It has 4 in the middle. It is the 300hp 5.7L vortex. It also has fuel rails on each side of the throttle body and a split intake manifold.
I mainly want to make sure all my ducks are in a row and I can get parts in a pinch at a local autoparts store if need be, before I start tearing into it.
Also depending on year the vortex intakes are different.
Old 02-22-2021 | 09:19 PM
4 center bolt valve covers doesn't automatically mean Vortec.
Look for 8 vertical intake manifold bolts. 4 at each end and none in the center. If you don't have that. You dont have a Vortec motor.
RSWORDS is offline
Old 02-22-2021 | 11:20 PM
I stand corrected, I made an assumption that the other versions of the 350 were not installed stock by mercruiser.
Old 02-23-2021 | 06:10 AM
No biggie. Mercruiser made the leap to all Vortec way after GM did.
RSWORDS is offline
Old 02-23-2021 | 09:03 AM
SB
Two piece intakes with plastic top, aluminum bottom are Vortec.
SB is offline
