MPI throttle body, >
MPI throttle body,
MPI throttle body,
Old 03-26-2021 | 08:08 AM
B38
Default MPI throttle body,
Is the 454 mpi throttle body the same as 502 throttle body.
B38 is offline
Old 03-26-2021 | 08:38 AM
SB
Here you go:
https://www.mercruiserparts.com/v-8-sterndrive-engines
SB is offline
Old 03-26-2021 | 09:20 AM
B38
Thank you.
yes same part number, 860204A5
B38 is offline
Old 03-26-2021 | 05:46 PM
Well.... There's a slight difference between throttle bodies based on what flame arrestor they used.
The first flame arrestor used was the dual dimpled cover with EFI stamped into it. It used the TB with the air horn installed into it.
The second flame arrestor used was the plastic housing and aluminum "fins" like an automotive radiator. It did not use that air horn device.
So it's not actually a 454 VS. 502 comparison, but I wanted to just let you know there are differences based on which TB was used.
xlint89 is offline
Old 03-26-2021 | 09:26 PM
B38
Thanks for the tip. Now I know.
B38 is offline
Old 03-28-2021 | 12:51 PM
TomZ's Avatar
I have a couple MEFI 3 throttle bodies with flame arrestors, TPS, and IAC if anyone needs parts. They're 1998s with under 400 hours usage.
TomZ is offline
Old 03-29-2021 | 10:29 PM
The small block MP/EFI motor of the same era (1995) had the same throttle body too, so you can widen your search if needed.
Trash is offline
Old 04-05-2021 | 08:23 AM
B38
Thanks all for the tips.
And yes, 454 MPI worked great on my 502.
All the same V8s
B38 is offline
