Trim cylinder bushings >
Old 04-21-2021 | 07:13 AM
Default Trim cylinder bushings
When I pick up on the drive there is some movement between the cylinder bushings and the shaft they slide onto, both top and bottom shaft. Is this normal or is the plastic bushing inside the rubber worn that much.
liberator221 is offline
Old 04-22-2021 | 05:56 PM
The rubber bushings in the ends of the cylinders? There shouldn’t really be any play between the rams and the drive. What do you mean by plastic inside the rubber?
IGetWet is offline
Old 04-22-2021 | 07:12 PM
Yes the rubber bushings on each in of the trim cylinders. There are plastic sleeves inside the bushings. So yours has no play? I didn’t think there should be any play but I couldn’t image that hard plastic wearing that much. Oh well a new set of bushings is less than $100 which in boat speak is almost free.
Old 04-22-2021 | 07:44 PM
No mine has no play in those bushings, pretty tight around the steel rods. Yea I was surprised they’re actually reasonably priced when I looked them up.
IGetWet is offline
Old 04-22-2021 | 09:47 PM
Are you talking about these bushings?
242LS is offline
Old 04-22-2021 | 10:51 PM
SB
Alpha Gen II have’m
SB is online now
Old 04-22-2021 | 10:56 PM
SB
https://www.mercruiserparts.com/bam/...30858/1017/120
#11​​​​​​​
SB is online now
Old 04-23-2021 | 06:48 AM
yes that’s the part. Common and easy to get I was just surprised they had worn.
Old 04-23-2021 | 04:36 PM
replace them all quick. Mine wore out causing play which I believe ended up causing the gimbal ring to break.
242LS is offline
