engine mount angle >
engine mount angle
engine mount angle
Old 05-04-2021 | 06:21 AM
Default engine mount angle
Hello All,
This may be a dumb question the boat has a Mercruiser bravo set-up with angle plate that the motor mount's sit on. Should the angle of the transom plate where the bolts and fiber washers sit be the same as the motor mount plates? Does anyone have a drawing from Mercruiser showing these dimensions?
Jeff
Zinger is offline
Old 05-04-2021 | 07:31 AM
Don't understand the "angle plate" but here is the engine install drawings
https://www.mercurymarine.com/en/us/...tion-drawings/
AllDodge is offline
Old 05-05-2021 | 09:57 PM
The rear transom mount should be at roughly the same angle, but the plane can vary for alignment purposes.
ACrooks69 is offline
