600 SCI cams
600 SCI cams
Two 600 SCI cams. These are billet core, roller, crane cams with an iron distributor gear out of my 600 SCI's, which are a Gen V block. I have no idea what the Crane part number is or any specs other than what I listed. $200 each plus the ride.
Here is what I know- the 600 uses a different cam than the 700 SCI. I'm 100% sure of this. The 700 SCI uses the 500 efi cam, that I am also 100% sure of. What is the 600 SCI? No idea, but it is not the 500/700 cam.
SB (05-11-2021)
NO problem. Just send cookies.
endeavour32 (05-11-2021)
Strange.......Merc shows 2 different cam part numbers for the 600SCI https://www.mercruiserparts.com/bam/...31375/14332/85
The 2409-849945T01 is listed for all 3 engines, but the 600SCI also shows 2409-8M0043066 listed.
As a note, when looking up any part on Bam’s mercruiserparts.com, if a part has a magnifying glass, click on it. Could be very valuable notes/info.
The following 2 users liked this post by SB:
endeavour32 (05-12-2021), Griff (05-12-2021)
